Excel & Project Scheduling
Just a quickie....has anyone used or developed a down & dirty Excel project scheduling spreadsheet?  One that would generate a Gannt chart?  Certainly not with all the features of MS Project or Primavera, but something useful?
CW
RE: Excel & Project Scheduling
One issue you run into with Excel, especially if your projects are long duration, is the column limitation.  An Excel sheet is currently limited to 256 columns (about 8.5 months), although this is slated to be increased to several thousand columns in the next release of Office.
They're going to fix all the bugs in Office in The Next Release, too.
Mike Halloran
Pembroke Pines, FL, USA
But will they get rid of Clippie once and for all?!
To not actually answer the original question,
... If you JUST want to produce a Gantt chart, a program called Fast Track Schedule might be helpful.
Like a lot of other Mac- rooted applications, it's completely hollow.
By which I mean, it produces a great looking printout, but _you_ do all the work.  It's a tool for _presenting_ a schedule, but it's of no help whatsoever in _generating_ one.
Okay, that was my impression of version 7.  It's up to version 8 or 9; maybe it's less feeble now.
Mike Halloran
Who's Clippie?
Pete, you don't use Microsoft products enough. smile
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
