File Icons unrecognizeable
Just set up my new XP Pro machine xeon 3.8 2gbram Nvidia 3450/4000 with the latest SW drivers running 1600 x 1200 32bit color. I have a problem with my file icons, they are barely recognizable look like very low resolution with a grey background and no little if color. Is there a setting that may fix this?
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: File Icons unrecognizeable
DO you have the video card set to SolidWorks?
Have you tried different (lower) screen resolutions?
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Yes its set for SolidWorks. I would rather not set a lower resolution. This is a higher end video than my old system running the same resolution and the icons looked fine. But I will test a lower res to see if that fixes it.
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Is this a new monitor also?
Does it have its own set of drivers?
Do you need to update your new BIOS for that monitor?
cheers
These are the same dell monitors as I was using with my old system. However, they report in device manager as plug and play so I need to update their drivers. I will try this and see what happens.
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Test your system for graphics memory stability, I have seen corrupt icons on a system with a videocard with broken video ram (windows stores the icons in your video ram, along with the background & some other gui stuff). Also try a different video driver. Are you using a DVI connector? If not, try the other monitor connector on your quadro.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
I am using 2 DVI connectors 1 for each monitor. This new system is giving me mre headaches. I just got booted out and it shut down unexpectedly. I rebooted and the bios is telling me that there was a previous thermal fault. The system is overheating, maybe its related to the graphics card
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Is this an "off the shelf" or "built yourself" system?
Is the CPU fan working?
Has heatsink thermal grease been applied properly ... or at all?
Has the system been overclocked?
Has this system been fitted with copper heatsink shims? Some of them don't fit properly & actually cause overheating.
cheers
Is this a problem with files you have opened and saved in this new system, or just files that have not yet been modified and saved anew?
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
You mention that latest, but are they the drivers SW has approved, and not just the latest ones from the Nvidia site... Also I have seen many people Downloading and installing the 64-bit drivers when they should be DLing the 32-bit drivers. List the driver verison and make sure its the 32-bit ones.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Sorry I didn't reply sooner, but I've been out of the office. It seems that my overheating problem was due to lack of good circulation around the PC. I moved the system out from under my desk to an open area and it hasn't shut down since.
As far as the corrupted file Icons go, they are still a problem. My video board is Nvidia Quadra FX 3450/4000 SDI  The video drivers I downloaded from SolidWorks approved driver list. I chose the Quadro FX 3450/4500 6.14.10.7756 10/17/2005. I ran the system and video diagnostics tests built into the Dell F12 boot interupt.
Just to reiterate, my file Icons in windows explorer are barely recognizeable, lack of detail and color regardless of the resolution I set my video at. The SolidWorks History tree looks OK, but icons in file dialog boxes look like the screen shot below.
The 1st screen shot shows my bad icons from my new system. the 2nd screen shot shows the same icons from my old system.
[URL=http://server4.pictiger.com/img/380247/computer-games-and-screenshots/bad-icons.php][IMG]
[URL=http://server4.pictiger.com/img/380248/computer-games-and-screenshots/good-icons.php][IMG]
thanks, Tom..
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
AnnaWood, thanks so much. This did the trick
this Forum Rocks...
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
