M+0.5*m for adding shaft mass to Jeffcott rotor
For a massless beam with simply-supported end conditions and a mass in the center, the Euler Beam model tells us we can easily find the stiffness (force divided by centerdisplacement) is
K = 48*E*I/L^3
and the first resonant frequency therefore
w1=sqrt(48*E*I/[M*L^3]))
Many references (Harris’ Shock and Vib Handbook, Mark’s Mechanical Engineering Handbook, Rao’s Mechanical Vibration, and Ehrlich’s Rotordynamics Handbook) suggest that you can enlarge the above formulation to provide for mass in the shaft as follows:
w1=sqrt(48*E*I/[(M + 0.5*m)*L^3]))
where M is center lumped mass and m is distributed mass of the beam (excluding center lumped mass).
Questions:
1 – Does anyone seen any proof or justification for M+0.5*m?
2 – What assumptions / approximations are made to arrive at this formulation (beyond Euler/Bernoulli beam assumptions)?
Note some more related discussion in thread384-156111
K = 48*E*I/L^3
Questions:
RE: M+0.5*m for adding shaft mass to Jeffcott rotor
of course when M=0 an exact solution is given,
f1=pi/(2*L^2)*sqrt(EIL/m)
hence w1 = pi^2/L^2*sqrt (EIL/m)
=sqrt(EI .5*pi^4 /(L^3*m*.5))
pi^4=97.4, so that's fairly close to 48*2
Cheers
Greg Locock
With a change in ratio m/M we can surely cause a change in deflection shape and with varying m/M it can't be "exact" (within the bounds of the model) for all m/M. Maybe the the deflection shapes are so close there's not more than 1 or 2% error regardless of m/M?
In our one lecture on rayleigh the point that was most strongly emphasised was that best results relied on using a 'natural' deformed shape for the structure. I think off-hand we worked through the effects of assuming a half sine, and a parabola, instead of the proper deflected beam shape, even for an unusual mass loading, the usual beam equation was best.
Cheers
Greg Locock
I used Maple to look at the effect of different assumptions for deflection (distributed mass deflection pattern or concentrated mass deflection pattern) upon the distributed mass critical frequency. I found the associated coefficient X~0.5 varies about 1% between these two extremes of deflection assumptions.
==============Symbols=============
w = radial resonant frequency of distributed mass beam
eqw = equation to calculate w from Raleigh's law using symmetry about x=L/2.
wdist = calculated value of w assuming distributed mass defection pattern (y(x)=sin(Pi*x/L)
wconc = calculated value of w assuming concentrated mass (in center) defection pattern (y(x)=x^3/12-L^2*x/16) - derived from beam theory.
eqwdist = eqw with distributed-mass deflection pattern
eqconc = eqw with concentrated-mass deflection pattern
==============Calcuations=============
> eqw:=w=sqrt(E*I1/mu*int(diff(y(x),x,x)^2,x=0..L/2)/int(y(x)^2,x=0..L/2)):
> eqwdist:=subs(y(x)=sin(Pi*x/L),eqw):
> wdist:=simplify(rhs(eqwdist));
wdist := Pi^2*(E*I1/mu/L^4)^(1/2)
> X:=evalf((sqrt(48*E*I1/(mu*L^4)))/wdist)^2;
X := .4927671479
(Above is value of X assuming distributed deflection pattern)
> eqwconst:=subs(y(x)=x^3/12-L^2*x/16,eqw):
> wconst:=simplify(rhs(eqwconst));
wconst := 4/17*105^(1/2)*17^(1/2)*(E*I1/mu/L^4)^(1/2)
> X:=evalf((sqrt(48*E*I1/(mu*L^4)))/wconst)^2;
X := .4857142865
(Above is value of X assuming concentrated deflection pattern)
$70 is still a little steep but I'll keep it on my wishlist at Alibris to see if a cheap one pops up (sometimes people do us a favor like rip a few pages which cuts the price in half).
I used Maple to look at the effect of different deflections and found not much difference in the coefficient X~0.5
Symbols
wdist = calculated value of w assuming distributed mass defection patter (y(x)=sin(Pi*x/L)
X := .4927671479
X := .4857142865
w = sqrt(48*E*I/[X*m*L^3])
I'm still admiring the neatness of that equation that uses all 5 of the first integers (cheating slightly) and ends up with pi.
So, the factor is 0.49 for all practical purposes. Excellent.
Cheers
Greg Locock
Cheers
Greg Locock
If we were trying to find w for distributed mass beam by trying various deflections, we would expect the lowest w corresponds to the correct inertial-loading deflection pattern, which is what we found.
Theory of vibration with applications by William Thomson has an example applied to a cam with follower and valve as commonly found in engines.
mass matrix= (m/420) [156 22L 54 -13L
22L 4L^2 13L -3L^2
54 13L 156 -22L
-13L -3L^2 -22L 4L^2]
with the usual displacements at the nodes [x1 theta1 x2 theta2]^t .
Since one does not consider the kinetic energy (virtual work term in FE derivation) from other displacements, should you just set them to 0? If so, this should reduce to (in the virtual work equation) m(156+54)/420 = m/2. Really, the m would be for each half of the supporting beam - 2 elements, but still gives m/2.
Or, one could consider it as ElPete does.
I see your matrix matches equation 14.3 of "Vibration Simulation using Matlab and Ansys" by Hatch. There is some discussion there about the consistent mass matrix being introduced to model distributed mass beam element. It's a little bit above my head. I'll study it a little more if I have a chance. (unless you want to explain it some more... )
The kinetic energy is defined as 0.5 * Meff * (x')^2. In this case, he uses y' instead of x' because of the vertical deflection.
To get y', he uses the deflection equation of a simply supported beam with a concentrated load at the middle of the span. He provides an equation for the deflection of the first half of the span as y = ymax * f(x).
He integrates over the length of the beam to get the maximum kinetic energy. With a wave of the hands, a little smoke and mirrors, the effective mass is calculated to be M + .4857m.
Steve
My copy also has the spring example (Example 2.4-1, pages 24-25). The one thing that I don't understand in the integral for kinetic energy is that the mass of the spring mspring is divided by its length, l.
Steve
Back to the case of lateral vibration, if there is a cantilevered shaft with a lumped mass on the end, we express the natural frequency as
w = SQRT(3*E*I / ((Mlumped+0.23*Mshaft)*L^3)).
Solving for the coefficient X=0.23 using similar approach as above, I got
X = 0.236 applying Raleigh's method with deflection pattern corresopnding to concentrated mass only.
X = 0.241 applying Raleigh's method with deflection pattern corresopnding to distributed mass only.
Since the real deflection is influenced both by concentrated (lumped) mass at the end as well as distributed shaft mass, I assume actual deflection would be somewhere between the two, I assume X lies somewhere between those two numbers.
Here are the details of those calcualtions:
http://ho
(please let me know if that links doesn't work)
Steve - did you notice M + .4857m is the same as I calculated using distributed mass defelction pattern in my post above (21 Jun 06 23:20)? No smoke and mirrors there I hope.
k = 3*E*I/L3, E = tension type spring
For the torsional spring (normal coiled wire) we have
k = G*d4/(64*n*R3)
In this case:
n = number of coils
R = coil radius
d = wire diameter
About your calcualtions, I think I have to dust-off my mathcad copy, since it have been a while I put my teeth in some higher math.
The shape that the beam would assume under gravity can always be calculated by 4 integrations. It will be a polynomial of order at most 4 assuming concentrated masses and uniformly distributed masses.
But that is not the first shape of the pinned/pinned beam with uniformly distributed mass...it's mode shape I know from Den Hartog and others is a sinusoid.
I used the sinusoid for the above case, but the other cases I used static deflection (pinned/pinned beam with mass concentrated in the center, cantilever beam with uniform mass, cantilever beam with concentrated mass on the end).
It seems to me I saw in a book that I could use the static deflection shape but that is incorrect at least ine some cases. Are there circumstances under which the first mode shape is the same as the static deflection mode shape? Maybe that holds when there are lumped masses only?
(if this thread has become too muddled with my rambling, I may start a new thread with a more concise statement of my question).
In the Thompson book mentioned, later he states (ex 10.5-2) that 0.5 M (if you use your example) would work. Still later Thompson, but only briefly, covers the Ritz method (Rayleigh-Ritz in the book). If you use this approach you can use another shape to approximate the mode.
Use assumed modes that meet the boundary conditions for best results. You can use two or more less accurate assumed mode shapes and arrive at a pretty good result.
As I mentioned above, using the static deflection curve as the mode shape gave much better results than a half sine wave only.
Cheers
Greg Locock
The 48EI/L^3 comes conveniently from beam equations, or one could look at the stored energy as 1/2 (48EI/L^3)*d^2 - with d as the deflection in the center. Other deflections besides the cubic that goes with a central force application may produce different potential energies.
"The shape that the beam would assume under gravity can always be calculated by 4 integrations. It will be a polynomial of order at most 4 assuming concentrated masses and uniformly distributed masses."
You get a 4th order polynomial because of the assumptions made in the derivation. Namely, dy/dx = tan (theta) = theta, for small values of theta.
It's like developing the differential equation for a pendulum. In order to solve it analytically, you need to substitute theta for sine(theta).
Steve
Steve - you're right that's an approximation inherent in many beam solutions. I don't lose much sleep over that one. Has got to be way out there in the umpteenth decimal place.
Bill. Your thought is important and it steers me towards a related question: how do we go from point A (A1,A2) to point B where:
A1 is w1=sqrt(48*E*I/[M*L^3])) for massless shaft with concentrated M in the center
A2 is w2=sqrt(48*E*I/[X*m*L^3])) where X~0.5 for beam with uniformly distributed mass.
B is w=sqrt(48*E*I/[(M + 0.5*m)*L^3])) for both distributed mass totaling m and concentrated mass M in the center.
I can think of two ways to combine A1, A2 to arrive at conclusion B and neither is exact (even if I knew some exact value of X calculated from beam alone):
The first way to combine A1 and A2 (which Bill correctly identified as my approach) is to combine them is to assume that the distributed mass beam acts like a SDOF mass system with same resonant frequency. The spring constant is assumed to be comparable to that taken from the other geoemtry (mass in middle), and calculate resulting effective mass X*m. Then if we believe the beam acts like spring with two masses on the end, we can just add the masses. Interesting Ehrich Handbook of Rotordynamics makes a similar related comparision on page 1.20. Here he compares the effect of adding series stifness to the uniform-mass beam and concludes it is the same as the effect upon frequency as adding series stiffness to the Jeffcot rotor (massless beam with concentrated mass in the middel) to within 2.5%. From my thinking, it is related in that in both cases the distributed mass beam is acting pretty much like a SDOF mass spring system.
The second way would be to apply Dunkerly's equation.
1/(w^2) <= 1/w1^2 + 1/w2^2
If we apply w1 and w2 as identified in A1 and A2, we get the correct w as identified in B.
Dunkerly's equation as far as I understand it comes close to being an equality if there are no other resonant frequencies which are close to the first (i.e. if the 2nd resonant frequency is 10x as high as the first the inequality is almost an equality).
That's the end of my discussion on the two ways to combine A1 and A2. Any comments on those or other ways to combine them?
One more thought: if I wanted to try to get a most-accurate estimate (still within the bounds of the Euler beam model), I guess the best approach (short of a numerical solution for a specific case), would be Raleigh Ritz of the entire system including both concentrated and distributed mass, rather than breaking it into two pieces. I'm sure that would not be practical by hand but maybe not too hard with Maple. Or are there other approaches... what do you guys think?
> theta:=0.1/12;
theta := 0.008333333333
> sin(theta);
0.008333236883
> (theta-sin(theta))/theta;
0.00001157400000
It seems negligible in most cases but still good to recognize what assumptions are built into our models.
tan (theta) = dy /dx = (0.1/12)
theta = arctan(0.1/12) = 0.00833314
(0.1 / 12) = 0.00833333
Like you said, not much of a difference!
You’ve been talking about using Rayleigh’s principle. That’s all it takes to arrive at B.
Assume a shape, determine the beam potential energy to get the ‘k’. Determine the mass from the kinetic energy; this has two parts the continuous and the discrete.
Ke= 1/2*m/L (v^2)int(0 … L/2) shape dx + (1/2)v^2*M* shape(L/2)
shape(L/2) is the shape function evaluated at L/2; this gives the discrete kinetic energy due to the mass in the center, at L/2. Now, v – the velocity is a scaling factor, the time derivative of the displacement at the center (i.e. v=-omega*sin(omega t) *d).
When you scale the shape from the location of the discrete mass, you get the 1*M. The continuous part comes from the integral.
If you locate the mass elsewhere besides the middle, depending upon how you set up the shape and scaling, you can get different constants for M and m.
I think the static deflection IS the correct first mode shape IF there is only a concentrated mass present. At any moment in time, pick a force applied to the beam by concentrated mass. The beam having no mass responds instantly to that force (using shape predicted by the static beam equations). The shape is the same as the static defleciton shape. Does anyone agree/disagree?
So I do think the deflection patterns that I used in my 21 Jun 06 23:20 post do correctly represent the deflection for the two extreme cases... one when M=0 (y=sin(pi*x/L) and one when m=0 (y=x^3/12-L^2*x/16).
Also note that using these two deflection patterns for their respective mass distributions with Raleigh's method does correctly predict the natural frequencies:
w=sqrt(48*E*I1/(mu*L^4)) for center mass only
w=sqrt(pi^4*E*I1/mu/L^4) for distributed mass only
Bill - I thought about it for awhile and I think I see what you are saying about Raleigh providing the means to get from A to B.
The Raleigh's formula is something like:
w^2 = [numerator]/[denominator] = [PE] / [KE/w^2]
Separate the problem into two different problems, one with the distributed mass m and one with concetnrated mass M.
Both have the same PE so both have the same numerator.
We have to add the KE's, so we "add" the denominators.
More precisely adding KE's amounts to adding the reciprocals of w^2 i.e.
Equation1: 1/w^2 = 1/w1^2 + 1/w2^2 where w1 and w2 come from analysis of the beam each with only one of the masses.
Now an interesting thing that confused me for awhile... this appears in conflict with Dunkerly's law that tells us that
Equation 2: 1/w^2 < 1/w1^2 + 1/w2^2 (different because here is an inequality vs equality above)
I think the resolution of that apparent conflict between Eq1 and Eq2 is that if we did a real solution of w1 and w2 for the different mass distributions per Dunkerly (Eq2), we would use a different deflection pattern y(x) for each one (depending on mode shape associated with that mass). But we used the same deflection pattern for both masses to come up with Equation 1. The difference between Equation 1 and 2 comes from this differnece in treatment of deflection pattern. Does anyone agree/disagree?
Now I tried to use Raleigh Ritz to analyse the problem of shaft with distributed mass and center mass here:
http:/
By the way I forgot to define my symnbol mu. mu = m/L is mass per shaft lenght.
I used two different deflections: one corresponding to the uniform-density beam with no center mass, the other corresponding to the mass-less beam with center mass.
The result for the general case is obscenely complicated and doesn't give me any insight. I need to think about how to reformulate it to see if I can show something useful. (any suggestions are welcome?). At any rate it could be used to compute the frequency if exact values of M, mu, L and I are known.
At the end of the file, I did check the frequency when m=0 and when M=0 and results were as expected.
http://
I added a check that Raleigh Ritz selected the proper modeshape in the extreme conditions M=0 and mu=m=0. The results were as expected.
The general modeshape was:
y(x) = c1*y1(x) + c2*y2(x)
where
y1(x):=sin(Pi*x/L) is the known modeshape when M=0
y2(x):=-x^3/12+L^2*x/16 is the known modeshape when mu=0 (applies only over the range 0<x<L/2 which is the range used in these calcs).
The checks added at the end show that the solution forces c1 to 0 when mu goes to 0. This removes the center-concentrated-mass modeshape and leaves only the distributed-mass mode-shape as expected.
Also the equation for c1 blows up when M goes to 0 (can be seen by inspection of algebraic expression c1solution1 which has M in the denominator). This means we need to set C2 to 0 to keep C1 finite. C2 going to 0 removes the distributed mass mode-shape and leaves only the concentrated mass mode-shape as expected.
So in this case it seems like Raleigh Ritz did it's job of automatically selecting the right mode-shape.
Now I have one more question. If I have some general mu and M not equal to 0, Raleigh Ritz will select a mode shape. Is this guaranteed in this case to be the correct mode shape (within the usual assumptions of Euler beam model)?
It seems logical to me that we might apply some kind of superposition argument to say that any modeshape which arises from superposition of masses mu and M will be a superposition of the associated mode-shapes. Would this be a correct statements?
"The checks added at the end show that the solution forces c1 to 0 when mu goes to 0. This removes the distributed-mass modeshape and leaves only the concentrated-mass mode-shape as expected.
Also the equation for c1 blows up when M goes to 0 (can be seen by inspection of algebraic expression c1solution1 which has M in the denominator). This means we need to set C2 to 0 to keep C1 finite. C2 going to 0 removes the concentrated mass mode-shape and leaves only the distributed mass mode-shape as expected."
Is there any basis to conclude that the exact mode-shape for an arbitrary combination of concentrated and uniformlty-distributed mass will be a linear combinatino of the mode shapes associated with concentrated mass alone and distributed mass alone?
There is no reason to suspect that the actual mode shape if a finite combination of shapes or mode shapes from another system (i.e. wlithout the concentrated mass).
Now another question. If my beam had only discrete masses attached (no distributed mass), then wouldn't the fundamental mode shape of the beam with all masses be a linear combination of each of the fundamental mode shapes for the beam with only one mass attached?
It seems the answer to this one should be yes. The fundamental mode shape for one mass attached is the static deflection resulting from force of the weight acting on the beam.
If we attach multiple discrete masses, we have at any given time multiple forces, each one causing an instantaneous reponse proportional to the static deflection. We can add the response to these forces by superposition. The response to the sum of the forces of all those masses should be a linear combination of the static deflections. Right?
Since this is not a continuous system there would be only N modes. Thus the dimension of the solution space is N, and all deflections are linear combinations of the any N deflections, static deflections or not.
Partly the purpose of my question is to confirm that a beam with one mass attached has fundamental modeshape equal to the static deflection pattern, and further if many masses attached the continuos fundamental modeshape is a linear combination of the deflection patterns of the individal masses.
I believe we could also solve the problem exactly by continuous Ritz-Raleigh. I also believe that if we chose the static deformations associated with each of the individual masses, then Ritz-Raleigh would give an exact solution. (but an arbitrary set of N linearly independent continuous mode shapes would of course not give an exact solution).
Might be a good excercize for me to try and compare both approaches someday.
Hmm. Maybe it is. I don't /think/ it is.
Cheers
Greg Locock
The way I look at it, the massless beam has to respond instantaneously to any applied force (unlike a distributed mass beam which cannot respond instantaneously). So look at the system vibrating at resonance take a snapshot in time. Each discrete mass is applying a force to the beam, and the beam is responding (instantly) to each of those forces with a deformation proportional to the associated static deflection pattern. So the mode shape has to be a linear combination of the static deflections associated with each of the masses individually. Or maybe that's faulty logic?
One example of this would be analysis of the simple massless-beam with concentrated rotor on the center. If we use discrete analysis, stiffness k=48*E*I/L^3, and radian frequency w=sqrt(k/m) = sqrt(48*E*I/[L^3*m])
If we use Raleigh assuming the static mode shape (derived in the file below as y(x)=-x^3/12+ L^2*x/16), we get exactly the same result for frequency w, which seems to approx that the static deflection is the correct mode-shape at least in this case. Raleigh analysis of this simple case using static mode shape is here:
http://ho
or here if you like pop-up screens:
http://electricpete1.tripod.com/LinkToRaleigh.htm
The idea of dividing the continuous beam into small pieces is interesting. It seems like we would have superposition of an infinite number of infinitessimal static deflections? I'm not sure I can see where that leads us.
"If we use Raleigh assuming the static mode shape (derived in the file below as y(x)=-x^3/12+ L^2*x/16), we get exactly the same result for frequency w, which seems to prove that the static deflection is the correct mode-shape at least in this case. Raleigh analysis of this simple case using static mode shape is here:"
Well, Leibnitz and Newton found that a handy approach!
I'll see if it makes any sense tonight.
Cheers
Greg Locock
In the meantime, I tried the excercize again. This time I used a massless beam with two attached concentrated masses. The masses are attached a distance "a" from each end. The beam is simply supported on both ends like the previous example.
First I calculated the static deflection. Then plugged that into Raleigh's to find the first critical frequency. The result was
w^2 := [6/a^2] * [I1*E] /[(3*L-4*a)*M]
This matches the frequency given in DeSilva's "Vibration and Shock Handbook" table 34.2. He references Blevins.
This would again seem to support (but doesn't prove) the idea that the first mode shape for a massless beam with discrete masses attached is a linear combination of static deflections from individual masses.
Here are the calculations. Sorry for the popups...I'm having trouble with my normal server at houston.rr.com
ht
We'd have to integrate that piecewise expressoin for a from 0 to L. The problem is that the dividing point between the pieces changes for every differential element (since a is the dividing point).
I can't see any way to do it.
Here's my thoughts from the drive home:
(1)Static bending:
superposition applies (it's a passive linear system)
The deflected shape of a uniform beam under its own weight is therefore the sum of the deflections of a massless beam due to the weight of each beam element.
(2)Modal analysis:
The mode shape of a uniform beam should be the sum of the modeshapes of a massless beam with a notional point mass applied at even intervals along its length, independently.
Now, I am comfortable with (1)(but will check it), but very dubious of (2)(but will check it)- I don't know why I'm dubious.
We also have (3) electricpete's hypothesis: the (first?)(flexural?) mode shape of a (uniform?) beam with distributed and point masses is the same as the static deflection shape under the weight of the same masses.
In itself it sounds reasonable. Can I be completely evil and point out that a uniform beam supported free-free has a first flexural mode, but has no static deflection shape? That's probably too much of a nit-pick.
Anyway, I'll wander off for an hour or two of calculus or worse.
Before I do:
Two point masses, two equal springs in series, grounded at one end.
Statics: deflected shape is [2,3] (by inspection)
Dynamics: first mode shape is [2,1+5^.5] (Blevins)
Good. That encourages me. The mode shape is similar to, but not identical to, the static deflection shape.
Cheers
Greg Locock
Cheers
Greg Locock
I get that the deflected shape of a pin jointed uniform beam under its own weight q per unit length (usual approximations) is
EI/q*y=L/12*x^3-1/24*x^4-L^3/24*x
The first mode shape of the same beam is given by
sin (pi*x/L)
Hopefully if you drop the first expression into a Rayleigh equation you'll end up with a higher frequency than the second, which should give you pi/2/L^2*(EI/q)^.5
Cheers
Greg Locock
Cheers
Greg Locock
(3a) = the continuous mode shapes of a beam with point masses only (no distributed masses) are a linear combination of the static deflection shapes under the weight of each of the same masses.
(3b?) = the first continuous mode shape of a beam with point masses only (no distributed masses) is the static deflection shapes under the weight of the same masses. (?)
Just to repeat the justification for 3a: A massless beam responds instantaneously to any applied forces (whether time-varying or static). If we take a snapshot in time of the forces applied to the beam by the accelerating masses, then we know enough to construct the deflection. It is the same as the static deflection under those same forces. It is also a linear combination of the static deflection pattern of each of those masses.
3b is still open to debate. I don’t have any proof other than in one case (the two-mass shaft above) it was true.
(2) was suggested as a possible way to check (3b) taking the limit of many small masses. I don’t think the integral is doable (not for me anyway). While we don't know the result of the integral, we do know it should be the the static deflection of the continous beam which by the 4-integration method is a fourth-order polynomial. So it would not match the first mode shape which is a sin. On the surface that disproves 3b, but I’m not sure whether 3b might somehow still apply for discrete masses.
The excercize of two masses I think proves 3b wrong (I’m still thinking about it). It does not prove 3a wrong. It would be impossible to prove 3a wrong using discrete analysis because of the “linear combination” part.
To clarify which excercize I’m talking about, it should read: “Greg’s excercize of two masses I think proves 3b wrong..”
M – mass matrix - diagonal
K – stiffness matrix
w = weight vector – diagonal of M as a column time G
xs= static deflection = K^(-1)w
x1 = 1st modeshape, discrete
n1= first natural frequency
then
(n1)^2 M x1 = K x1 – eigenvector
Assume x1=xs then
(n1)^2 xs= M^(-1)K xs=M^(-1)K K^(-1)w
Or ,
(n1)^2 xs= M^(-1)w
Since M is diagonal and w=diag(M) G
M^(-1) w =G (1 1 … 1) ^t
Thus xs = G/(n1)^2 (1 1 … 1)^t
This would say that the static deflection is the same at all locations. It could happen for a particular choice of weights, but when there is more than weight, symmetry or not, this is unlikely.
Conclusion: xs is not x1 in general.
1 – If it were true, in the limit we would expect the static deflecton of a continuous beam (which we know to be a 4-th order polynomial) to be the same as first mode-shape (which we know to be a sinusoid). So it must not be true.
2 – Greg’s 2-DOF system had a fundamental modeshape which was not the static deflection shape.
3 – Bill’s analysis.
I should point out that 3b was just an off-hand comment that arose from analysing the beam with two masses. In that case not only was the continuous mode shape a linear combination of static deflections of individual masses (3A), but it was also THE static deflection shape from the combined weight loading (3B). That anomaly is explained in Bill’s writeup where it is shown this can occur when the static deflection involves the same movement of all masses.... which holds for the case of two masses equally distant from the two ends of the simply-supported beam.
I’m pretty confident that 3A remains true, although as Bill points out it doesnt’ have a lot of usefulness... other than as an aide to guessing approximate continuous shapes for Raleigh methods.
To elaborate on the above statement a little further:
1 – If there is only one discrete mass (and no distributed mass), then we know the mode shape exactly and can calculate the frequency exactly using continuous Raleigh as was done above at http://ho
2 – If there are multiple discrete masses (and no distributed mass), then we know the mode shape will exactly be some linear combination of the static mode shapes. Then we could use Raleigh Ritz to construct the exact continuous mode shape and find the exact frequency. (although we could solve the problem easier by discrete/matrix methods).
3 – If there is a combination of distributed and concentrated mass, the mode shape can’t be found from 3A. But the static deflection shape might be a fair starting point for an approximate solution from Raleigh or Raleigh Ritz.
I have my doubts about this. Any mode is a linear combination of the static deflection shapes which are cubic polynomials. At best this forms a 4-dimensional vector space over the real numbers. Thus, linear combinations of this could only produce up to 4 independent and still forms a cubic polynomial.
With n masses, linear combinations of the n independent mode shapes can produce arbitrary displacements at the mass locations, an n-dimensional vector space. However, a cubic polynomica cannot produce n, for n>4, arbitrary configurations.
Thus, linear combinations of the static deflections, a cubic, can not produce all the possible deflections necessarily. Likewise, linear combinations of the static deflections can not produce every mode shape. Why should the first mode be special?
This may involve solving a system with > 4 masses to see an actual modeshape. This could be very difficult to solve analytically.
Bill
The building blocks for this set of piecewise polynomials comes from the set of static deformation polynomials. Each static deformation polynomial has a different cubic polynomial on each side of associated mass. This gives us all the degrees of freedom we need to construct the full mode-shape piecewise accross the whole beam.
The strongest argument is again the physical argument. The massless beam has no memory and deflection at any instant in time is determined soley by the appliled forces at that instant in time. We know how to find the beam deflecton shape for a beam with 200 point forces... by the 4-integration method which will give us the required 201 piecewise polynomials.
The above conclusion in my mind applies to all N modeshapes. The first modeshape doesn't have any special role in conclusion 3a. It had a special role in the now-deceased conclusion 3b.
I’m sure it’s obvious to Bill and Greg and the others, but for the sake of completeness I’ll clarify that the 4-integration performed with 200 point forces is equivalent to the superposition of 200 static deformation solutions which was each obtained by 4-integrations of a single point force.
Linear combinations of the individual gravity sags will produce any mode shape.
Bill
Back to the subject of the beam with both distributed and concentrated mass. Assuming my goal were to accurately find the first resonant frequency:
What would be guidelines for choosing a set of shapes for Raleigh Ritz?
Should we have a set of shapes that approximate the first mode shape or should we try to have one shape for each of the first few mode shapes?
Greg – why did you suggest the set of sinusoids for the Raleigh Ritz approach?
Bill
In the meantime, I am still interested to know a little bit about selecting functions for Raleigh Ritz. Rao gives an example but doesn’t say much about selecting the functions.
Is the consistent mass method “exact” (with Euler assumptions), or just better than the lumped mass method?
If you do it symbolicly you will have an equation that you have to solve numerically - at least for all but the simplist problems.
Bill
Cheers
Greg Locock
Returning to the problem from a different angle - I think maybe the distributed mass beam with concentrated mass can be solved exactly as follows.
Rao gives the solution for the general solution for uniform mass beam as
y(x)=Asin(beta*x) + Bcos(beta*x) + Csinh(beta*x) + Dcosh(beta(x)
where argument beta =sqrt(w) * (mu/E/I) ^(1/4)
Since y(x) is only determined to within an arbitary multiplicative constant, we can arbitrarily set A=1.
Then we have 4 unknowns (B,C,D,w).
We can solve with 4 boundary conditions. Several examples such as pinned/pinned beam are solved.
I think we might be able to use the same approach for the beam with distributed mass mu and concentrated mass M by examining the interval [0,L/2]
The 4 boundary conditions:
y(0)=0 (pinned boundary on the left)
y’’(0)=0 (pinned boundary on the left)
y’(L/2) = 0 (from symmetry)
y’’’’(L/2) = E*I*w^2 * M
The last boundary condition listed is the tricky one. IF we assume for the moment that this were a massless beam, we could apply the rules of static beam deformation to arrive at that 4th equation, using the force from the beam F=w^2 * M. But if we are considering a single point on the beam only (L/2), I don’t think that the distributed mass can possibly change this relationship as it applies at a single point.
What do you guys think?
I’ll try it on Maple this weekend and see if the solution looks anything close to the solution we expect.
Maybe F=w^2*M*Y(L/2)?
I'm not sure any more. What do you guys think... can the force from that concentrated mass be captured in a boundary condition on the shape of the beam?
y’’’’(L/2) = E*I*w^2*M*Y(L/2) which still provides a required equation for a solution. I'm just not sure if it's gonig to be the right equation/solution.
1 – One mass is shared among two half-sections of beam. Therefore should use M/2 in place of M.
y’’’’(L/2) = E*I*w^2*(M/2)M*Y(L/2)
2 – I have to look carefully at whether a minus sign will be required for y’’’’(L/2), based on the sign convention used in derivation of the general form of the equation listed above.
I’m pretty sure with these corrections, the 4th equation would be valid. The justifcation:
1 – We know that if there we no mass in the beam, we could determine shape from forces applied. Additionally I don’t see how the presence of distributed mass will change this conclusion when we are looking only at a single point boundary condition at L/2.
2 – The mode shape corresponds to a snapshot when the deflection is maximum. The force applied by the mass at L/2 will also be maximum at that point in time in a direction equal/opposite of y. Since the mass force is sinusoidal in time and we have matched the maximum force with the maximum deflection, I think the dynamic nature of the force is properly captured.
But I know the solution of the case where M=0 and mu remains non-zero is y(x)=sin(x*Pi/L). Differentiating 4 times we have y’’’’(x)=sin(x*Pi/L). So Y’’’’(L/2) is not 0.
This seems to contradict the approach I outlined above.
Shouldn't this be y'''(0)=0?
If you are using symmetry and a boundary conditon of y'(L/2)=0, then I think you have to use M/2.
Bill
I agree with the M/2 instead of M.
h
The boundary condition that I wrote above as
y’’’’(L/2) = E*I*w^2*(M/2)*Y(L/2)
should have been
y’’’(L/2) = -E*I*w^2*(M/2)*Y(L/2)
In the correction immediately above, there is a change to minus sign on right as expected. Also the force from mass acceleration is related to the 3rd derivative (shear force), not the 4th derivative (force per length) as I had written before. This can be verified by examining the units.
Results for X vary from 0.4857 for very small MassRatio (m<<M) to 0.4927 for very high MassRatio (m>>M) . These match the results which can be derived for the case of distributed mass alone or concentrated mass alone. A table of X vs MassRatio is at the end of the worksheet.
To two decimal places it is 0.49 no matter what, so the values really aren't needed for any practical calculations. It was more of an excercize for me and I learned a lot by working through it and asking questions here.
I still have my assignment from Bill to solve using the transfer matrix which would be a useful excercize as well. Sometime in the near future...
m/M X
0.001 0.4857168063
0.01 0.4857480390
0.1 0.4860378548
0.2 0.4863333819
0.5 0.4870836626
1 0.4880107197
2 0.4891832972
5 0.4907094280
10 0.4915643189
100 0.4926253580
1000 0.4927527114
The boundary conditions:
> # Equation: y'(0)=0
> # Equation: y'(L)=0
> # Equation 3: y''(0)=k*y
> # Equation 4: y''(L/2)=k*y
Maple couldn't find a solution. It looks like I have 4 equations in the 4 uknowns so I don't know why there would be a problem. Maybe I'm overlooking something basic or did something stupid? Any ideas?
http:/
