Weld Symbol
Weld Symbol
Weld Symbol
I would like to weld two 1/8 fillet welds 1/4 inch long on 1” rod 180° apart. Which is the proper way to callout the weld per AMS 2.4:
1/8 (Fillet Symbol) 1/4”-180°
or:
1/8 (Fillet Symbol) 1/4”-1/2”
or:
1/8 (Fillet Symbol) 1/4”-2 23/64”
NOTE: 2 23/6 is the approximate circular distance around the perimeter of the rod.
RE: Weld Symbol
Check here:
http://www.welding.com/weld_symbols_welding_symbols.shtml
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: Weld Symbol
The basic question is what is the proper way to define the pitch on a circular weld path? Should you do it with an angle or a circular length?
RE: Weld Symbol
Sorry about that, I thought that web page would answer your question.  I would circular length unless the starting point is critical and you're not wanting it to go 360 deg.
