dimensions in drawing
Hello All,
New user question, why don't all dimensions used to build a model come in to the 2d drawing? I still have to create a number of dimensions for each drawing. I'm not the only one who does this apparently as I see 'grayed' dims on other peoples drawings as well.
Bob
RE: dimensions in drawing
A lot of people use driven dimensions in their drawings. Sometimes the way a model is created, does not reflect the way a part should be dimensioned for manufacture.
But to answer your question, it would be helpful if you explain which dimensions are not being inserted into the drawing. (Extruded length, pattern spacing, etc).
Are you selecting the correct options when inserting the Model Items?
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
CorBlimeyLimey,
it is the dim's that you mention, seemingly basic stuff like lengths and pattern info.
