inserting part dimention into drawing
How can I insert part dimention into drawing?
RE: inserting part dimention into drawing
Your first port of call should be the Online Tutorial found in the Help dropdown. Working through those will give you a good grounding in the basics of SW.
But to answer your question;
1) You can use Insert > Model Items and select the options you need from there.
2) Under Tools > Options > System Options > Drawings select Automatically place dimensions inserted from model and under {b[Tools > Options > Document Properties > Detailing[/b], in the Auto insert on view creation section, select Dimensions marked for drawing. This will automatically insert & place dimensions on the views as they are created on the drawing sheet.
3) Select the Smart Dimension icon under the Dimensions/Relations toolbar, then in the drawing, select the model element or vertices you want to dimension.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
CBL, which version of SW are you using?  I cannot find "select Dimensions marked for drawing".
Flores
SW06 SP4.1
SW05 ... but remember you need to have a drawing open to access that section of the options.
It may have changed for SW06, but I haven't had chance to load it yet.
cheers
