Contour Flange Profile Problem
I'm creating some Derived Parts. I have a master sketch in the first part for a set of related parts.
Some of my profile lines will not select properly. These are really simple parts. For example, I have 2 adjacent lines shaped like an "L". When I go to select it as the Profile for my Contour Flange it will only select one line (or the other). I've tried all the obvious things.
Any ideas? (I'm using v7)
RE: Contour Flange Profile Problem
