Need Rotation meter for VFDs
Can anyone recommend a phase rotation meter that will work on PWM VFD outputs.   My AEMC #PMR-1 meter seems to go nuts when I connect it.   I was thinking one of the old fashion rotating motor type meters would work.  Anyone solve this problem?
RE: Need Rotation meter for VFDs
The old fashioned electromechanical rotation meters should work fine, I used them as demos to show instant reversal capabilities of VFDs years ago (before people readily accepted the concept). Here's one similar to what I had.
http://www.kilowattclassroom.com/EquipSPD.htm
Eng-Tips: Help for your job, not for your homework  Read FAQ731-376
