How to separate bloks?
I use VBA to create block with attributes, but Autocad Map 2000 mixed new one with old one. What can I do?
RE: How to separate bloks?
"Everybody is ignorant, only on different subjects." — Will Rogers
Set blockTablo = ThisDrawing.Blocks.Add(insertPoint, blockName)
Then I add attributes.
Set blockTabloAttrib = blockTablo.AddAttribute(0.15, mode, "òðàôîïîñò", blockPoint, "ÒÏ", attrTrafopost)
All of source is working fine until now. The new block gets a part of old one. And the attributes are mixed. The value of attributes are written in cyrillic.
ObjectCount = ThisDrawing.Blocks.count
blockName = "ELTABLO_" + Str(ObjectCount + 1)
end it was worked.
