Drawing tree template
I'm looking for one with:
*A block for each assembly.
*The block looks like a table (rectangular border divided into regions, or cells)
*Each cell in the "table" contains a text attribute.
*There's a text attribute for each of the following: part number, drawing number, description, and reference designator.
*The blocks are connected with lines showing the product structure (assys, subassys, etc.).
*Under each assy is a subtree showing subassys and custom parts.
*When you click on a block a dialog window comes up showing the text attributes within.
In my experience most AutoCAD drawing trees are set up this way but I've been coming up empty-handed. A freebee would be great but we'd consider buying one.
Thanks!
Thanks!
Tunalover
RE: Drawing tree template
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
