BOX CULVERT THRU CONC. RET WALL JOINTING
Hi All,
I am using a box culvert for the purpose of stormwater detention. One end of the box (4x6-ft) will need to project thru a poured-in-place conc. retaining wall (wall height will be less than 6-ft). The box will have about 2.5-ft of cover material over it and will support a residential roadway.
Is there any need to specify a jointing material between the box and the wall? If so, what type will do think can do the job?
H.
H.
RE: BOX CULVERT THRU CONC. RET WALL JOINTING
Good Luck
R.A. Hassett, P.E.
rah1616@hotmail.com
