Stormwater Sediment Seperators
What is the most economical stormwater sediment seperator?
The use would be suburban 10-acre residential subdivision with (2) storm sewers discharging into a lake.
RE: Stormwater Sediment Seperators
In the state of Maryland, alot of storm water quality basins are build with wetland shelves and fringes and wetpool areas for settling and encouraging wetland vegetation for filtering effects.
These all take up land area, which of course the client isnt too happy about.
The subsequent runoff has to be routed other than thru the pond/basin. This is usually done by a junction box to separate the first flush and the later runoff. Usually done by weirs or some such method to shift flow patterns in the box.
