LT1264 and charge pump IC as supply
I was using a transformer based -5 supply to the LT1264 Bandpass filter without a problem until I tried using Microchip TC962 negative charge pump for the same negative supply instead of the transformer. The TC962 has 80ma output LT1264=23ma, max. Any conceptual blunders in trying this approach?
RE: LT1264 and charge pump IC as supply
Any problem ?
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
If you are having problems, you may want to use a device to generate your -5V that has low noise and ripple on the output. Some voltage inverters are designed for low noise for use in VCO or RF circuits, and some are followed by a low noise LDO.
Keith Cress
