image quality save?
image quality save?
is there anyway to "save" the image quality? If I set the slider to high, then do anything to the part (i.e. zoom in or out) the image quality goes back to low.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: image quality save?
I just did something this morning where I needed to see a round circle and it saved the image quality. My part templates are set up for low or fast performance. Not sure if someone else may have a suggestion for you. Did you try saving the part immediatly after changing the quality? You might want to let us know what version of SW you're running and all the particulars as far as video card etc.
SolidWorks 2006 SP4.0
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Matrox P650
Logitech Marble Mouse, CADMAN
SW2006 Sp2.1 (can't update due to the "insert CD2" snafu
Nvidia Quadro FX3400
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Have you figured out a solution to this issue? I've been having the same problem and it's annoying. I'm going to try contacting my VAR.
John Graham CSWP
Mechanical Design Engineer
Jeff Mowry
John Graham CSWP
If so, can you select the Apply To All Referenced Part Documents option?
Jeff Mowry
Good thought. That's what our VAR thought too. But it happens in parts that are not used in any assembly. I think it's just a bug.
John Graham CSWP
