ProE part using ATB will not update after CATIA file changed
We are running into the following problem:
1) In Tools > Options we enable "topobus_enable" (set to yes)
2) We open a CATIA V5 model file in ProE as a part
3) We save and then close the ProE part
4) We open the same CATIA V5 model file in CATIA and modify it, save it and close it.
5) We open the ProE part and it does not update
6) The command File > ATB > Update does not update the part
In short we can't get ATB to work.
Please send your comments and suggestions.
Thank you,
Joseph
RE: ProE part using ATB will not update after CATIA file changed
We have the CATIA model and ProE part in the same folder.
We set the atb_search_path to this folder.
Unfortunately, we still have this problem (the ProE part does not update).
However, if we open the CATIA model again in ProE we can see that it changed. But the original ProE part that is supposed to be linked via ATB never updates.
Any ideas are welcome.
Cheers,
Joseph
The default value of atb_auto_check_on_update is 'off', whereas the atb_auto_check_on_retrieve is 'on', so you might need to change that option.
Another possibility may be spaces in your folder name. Pro/E can get moody when paths have spaces in them.
I agree with JKG, the atb_auto_check_on must be set to ON
-Hora
Thanks to everyone for your help.
We contacted PTC support, and at the moment the problem we are having appears to be a bug with the license files. So at the moment we are awaiting for some clarification from PTC.
Shall keep you posted.
Cheers,
Joseph
thanks Texaspete.
You'll have only dumb solids. As well as STEP. The advantage using the ATB bus is the automatic update of the non-ProE components used in your assembly.
-Hora
Thanks again, yes this was an SPR relating to a problem with license files.
Cheers,
Joseph
Glad to hear its working
-Hora
