Question about Rp...
Dear cybermen and cyberwomen,
I wish want ask  a very simple question to you , I hope that someone answer me as soon as possible!!
Is there one formula that it converts Rp(0,2)t into Rp(1,0)t for austenitic steels, for example?
If it thereisn't, how I do to obtain the value of Rp(1,0)t of these materials?
Thanks to everybody that I will answer me.
Eng. Antonino Nicosia
my website: web.tiscali.it/aeronavigandosulweb
RE: Question about Rp...
23021972;
The terms Rp (1.0) and Rp(0.2) refer to proof (tensile yield) stress values at 1% and 0.2% permanent deformation, respectively. These values are determined from standard tensile tests, and there is no conversion formula.
Thanks metengr
but I know it, I ask you if there was some particular formula to compute this conversion...do you know Roark's formulas for structural field? I searched something of similar...
To obtain Rp(1.0) values, you need to coduct tensile tests and obtain this data at 1% strain.
There is no specific formula to convert among proof stresses at varying strain levels.
If the material follows a hardening law (like Holloman), then you may be able to use that.
Use an Internet search engine and look for Holloman, strain, hardening.
Cory
thanks!
Aeronautical Engineer specialized in Fluid Power field.
(in the future there will be many programs about fluid power problems, thermal and structural problems)
