what decide valve torque?
I am curious about how to decide the valve torque? just pick up from handbook or national standard data?
and what about stem diameter, stem thrust? if need caculate, how?
RE: what decide valve torque?
The torque is a function of the particular valve design - and the working pressure. A ball valve with a Teflon seat ring requires less torque than the same valve body with a graphite seat ring suitable for fire rating. The manufacturer either publishes the torque or can furnish that data.
I recently obtained data on the 87/88 series Apollo valves. There are four sets of tables, one set for the 87/88A100 series and one for the 87/88 200 series all Class 150 and another pair of tables for Class 300. The first column is port size for Class 150 with rows for each size from small such as NPS 1/2 to large, such as NPS 12. The pressure tables range from 0 increasing by 100 psig to the maximum for the flange class. A torque value exists in each block corresponding to the size and pressure. The next to last column shows the LSST with torque and the last column shows an adder for option 24. Option 24 is the graphite packing and seal.
The actuator torque at minimum air pressure must exceed the valve torque. Actuator data includes the torque from the piston and torque from the spring. Further detail applies to the curve between the start and end of travel.
You did not specify ball valves in your question, though. Butterfly valves also have torque consideretions:
Type of valve, seat material, process fluid velocity and density, packing material all affect the torque required. Again, there is no national standard and there is much variation between similar valves from different nmanufacturers. Consult the manufacturer's literature.
