Retaining Wall
Retaining Wall
How do you determine a how much of a heel you need for a concrete retaining wall with no toe. The wall holds up about 15.75 feet of soil on the toe side and 3 feet of soil on the heel side.
Sincerely,
Calif
Sincerely,
Calif
The resisant virtues of the structure that we seek depend on their form; it is through their form that they are stable, not because of an awkward accumulation of material. There is nothing more noble and elegant from an intellectual viewpoint than this: to resist through form. Eladio Dieste
RE: Retaining Wall
RE: Retaining Wall
Sincerely,
Calif
RE: Retaining Wall
RE: Retaining Wall
You can always, too, "reinforce" the front of the wall by putting the wall on a piled foundation;
you can take overturning moments (which is causing the higher "front face" pressures) by using ground anchors or dead-man anchors.
Also, there is some published data that suggest that the real 'front face' pressure (toe pressure) is not as high as theory indicates - sorry, can't remember the source off-hand but it was for some State DOT, I believe.
UcfSE has hit the nail on the head for so many engineers! Good one!
RE: Retaining Wall
1. Do your overturning moment analysis.
2. Do your resisting momentanalysis.
3. Check your factor of safety.
4. Sketch your bearing pressure diagram.
5. Determine if the bearing pressure is acceptable, depending upon your geotechnical consultants recommendation.
6. Check your total active force.
7. Determine whether there's enough material in front of the wall. The passive pressure and where it starts is also from your geotechnical consultant.
8. If you don't have enough resisting pressure, then add a key, varying the depth until you have enough sliding resistance with a factor of safety.
If you do this all on a spreadsheet and you document the spreadsheet carefully, you'll have a little routine to play what if with and to use later.
The bearing pressure is P/A +/- M/S if the bearing pressure is over the whole length of the bottom of the footing. If you have "tension", then use the method for determining the maximum pressure on a triangular section that doesn't have the whole length of the footing under pressure.
Chapter 12 of Schaum's Concrete book has very good examples that you can look at.
RE: Retaining Wall
Use an example with a toe but make the toe about 0.01 feet long.
