using different version of compiliers
I have to code a visual c++ programme with abaqus..
I hav taken the sample programme given in the user manual abaqus version 6.6 ...and after compiling it is giving an error like part is not meshed..
i have taken the sample programme as it is..but it is still showing the error.
and compiler used is older version is thr any possibility that this could b th problem.
help appreciated,..
thank u
RE: using different version of compiliers
Is this for school?
TTFN
no not actually ..
i am learing from the user manual.
You'd have better luck at www.tek-tips.com
TTFN
What sort of errors are you getting?  The older versions of the compiler are 16/32 bit.  VS6 is 32 bit only.  Some later editions support 64bit.  M$ made a lot of changes between versions.  For instance underscores have been added to a lot of 'non standard' routines.
