Basic Question
Basic Question
Hi
I have a basic question
I was trying to calculate the torque axis at the rear suspension for an AWD, the way I understand it is the resultant of the driveshaft torque axis and the halfshaft torque axis , now if I consider them as 2 3D vectors having different origins , and I want to calculate the resultant torque axis , how can I do that
I mean I am trying to understand the math behind it
Thanks for your help
RE: Basic Question
Additional very big clue, it doesn't matter where on a rigid body you apply a pure torque.
Cheers
Greg Locock
RE: Basic Question
I know enough to know you give good info, and I don't understand this. Intuitivly it seems like it should matter where your force is as it changes the distance the force is acting over making it a different length lever arm, Or are all forces on a rigid body acting on the center of force for that body?
RE: Basic Question
It is an odd result intuitively, largely because in the real world we usually apply a pair of forces to get a torque, rather than a pure torque.
Cheers
Greg Locock
