Is there a slope formula for calculating horiz tilt in a slope?
I'm designing some precast coping for a wall that has a vertical slope from EL.3'-0" up to EL.10-0"
This coping will be sloping in a semi-circle, similar to a spiral staircase.
If I'm not mistaken, this coping will have to tilt inward or twist as it slopes up.
Is there a formula that will give me the amount of twist in ea segment of coping?
adaugherty
adaugherty
RE: Is there a slope formula for calculating horiz tilt in a slope?
In any case, 3D trigonometry converted to 2D trough orthogonal planes should solve any of your problems. Depending of the case, a polar or cylindrical coordinates system may help a bit.
