Earthquakes, is it a shock or random vibration event?
Im looking at a spec and it describes the earthquake in a SRS (Gs vs Hz) profile, but I thought it would be described in a random vibe (G^2/Hz vs Hz) because earthquakes can last longer than typical shocks (pulse, velocity,…).
Any help would be greatly appreciated.
Tobalcane
"If you avoid failure, you also avoid success."
RE: Earthquakes, is it a shock or random vibration event?
Earthquakes are neither of those strictly speaking, as they fall under their own "seismic" type event. The g vs Hz is a response spectrum converted from a time history using single DOF springs on masses. This gives a characteristic shape of spectrum, which shock or impact spectra differ from greatly. The seismic response spectrum will have in general the greatest (most damaging) energy associated with the 5-12 Hz range, whilst the shock/impact damaging frequency will generally be a lot higher (in 100+ Hz range). Industry standard in the nuclear industry for the analysis of systems/structures is to use response spectrum for seismic and time history for shock/impact.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Thank you Drej for your response (no pun intended).
Tobalcane
Another question Drej, how would you run that on a shaker table?  I mean would you use a G^2/Hz vs Hz profile to simulate the earthquake?
Thanks!
Tobalcane
No, G^2/Hz vs Hz is a Power Spectral Density input (PSD), which is generally a random vibration signal. You need to obtain either the time history (e.g. acceleration/velocity/displacement vs. time) for the event or the response spectrum (e.g. force/acceleration/velocity/displacement vs. Hz) to represent the seismic input. Whether you use one or the other depends on the results you need as well as computer resources.
Thanks Drej!
Tobalcane
