Detailing holes or threads in section or side views
Other than manually typing the information in as a note is there a way to have Solidworks detail the hole automatically in a side or section view?
RE: Detailing holes or threads in section or side views
rikonen
If I understand you correctly.  Would it be possible to create and save the note as a favourite.  You could then add the note favourite to the dimension or hole callout instead of manually performing the option everytime.  Just a suggestion.
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
SW will only add dimensions (tapped etc...) in the plan view not from a side view... you will have to manully add a note there.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
It will if you use Insert > Model Items and select the Hole Wizard Profiles option.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
