Can SW06 import an Inventor assembly file?
Hi Folks,
I think that I know the answer to this one but want to check in with everyone to be sure. SW06 can open Inventor part files but there is not any option for assembly files. Is this correct? If so, is there any work-around?
Please pardon the fact that I am blissfully unaware of any of the specifics regarding Inventor (other than it is an Autodesk product). ;)
Best regards,
Best regards,
Chris Gervais
Application Engineeer
CADD Edge
RE: Can SW06 import an Inventor assembly file?
YOu might look at some type of translator programs like formatworks... not sure if they support that or not, but its worth a try.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I would export the Inventor assembly as a iges, or Step. I doubt exports to parasolid.
Does anybody know what Kernal Inventor uses?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
I was under the impression that Autodesk was still using the ACIS kernel. I don't know that for certain though.
Thanks for the feedback.
Best regards,
Chris Gervais
CADD Edge
