Material suggestions for intake manifold 'box'
I'm thinking of a type of plastic box to surround or place the manifold in to isolate it from engine compartment heat. Race cars use carbon fiber, and that's maybe the way to go, depending on how it's constructed and who's doing it.
I can't do CF, so something in flat panels maybe that I can cut and fit as needed. At least for the prototype. Flat panels could be used in this application.
The best material would be low cost, provide high resistance to heat trying transfer through it, and able to survive long term in an underhood environment's varied operating conditions.
Or, if not flat panels, what type of canned, part A/part B material is suggested? Just Fiberglas?
Any minimum thickness recommendations?
RE: Material suggestions for intake manifold 'box'
Cheers
Greg Locock
You can put it in a box, but what will keep it cool? Or for that matter, at least at times, what will keep it from staying hotter than no box at all? Some just use insulating spacers between the head(s) and manifold.
Cheers , Pete.
Insulating spacers are part of the overall plan. At a local cruise a Superformance Cobra had a spacer under the carb...the carb was cold to the touch, the engine was hot enough to fry an egg on.
I can get ambient hi pressure air from the base of the windshield to circulate through the 'box'.
I don't think the intake would still heat up, not with the 'box' encircling the intake all the way around. Except for where the intake runners meet the heads.
Corvette Lemans cars have their intake in a CF or ? box don't they?
With the right material, the heat couldn't get through easily. Do to space restrictions and for a more cosmetically pleasing appearance, I really wanted make a box that follows the contours of the intake to fit like a glove, but with an air gap between the two of course. Could even lay up fiberglas over a manifold I guess, but a material with more resistance to heat penetration would be better.
The intake's not curvy, mostly straight lines so to speak.
As for spacers, you need to remember that anything you add between the manifold and the cylinder head is basically adding to the total length of the port. Most spacers are placed between the manifold and carb/throttle body. There are also materials available to allow you to coat the manifold further holding down the temp. I would also consider some type of cold air duct into the airbox.
Larry Coyle
Larry Coyle
Cylinder Head Engineering, LLC
www.cylinderheadengineering.com
-b
