Alkalinity- protects or promotes embedded steel corrosion?
Do the alkaline properties of concrete help protect or promote corrosion of steel embedded in concrete? I've read it both ways. Who's right? -Kent
RE: Alkalinity- protects or promotes embedded steel corrosion?
Heres the but, if the concrete was made using the wrong type of sand/aggregate, the alkalinity of the concrete in conjuction with the silica in the aggregate can cause an effect called Alkali Silica Reaction (or Alkali Aggregate Reaction). This results in a gel which absorbs water, expands and causes the concrete to spall. While this does not cause the reinforcement to corrode directly, once it has occured the cover to the reinforcement has failed and corrosion can take place unabated.
We have had quite a problem with older concrete bridges in the UK experiencing this.
Dik
dik...mostly chalcedony cherts and similar soft, amorphous silica forms
http://www.tnemec.com/history.asp
All portland cement concrete is highly alkaline. It is only when there are certain forms of silica in the mix that such reactions take place. Similar reactions can take place with carbonate aggregates.
A relatively high alkalinity is necessary to protect the rebar. If the pH of the concrete falls below about 10, the potential for rebar corrosion increases. Further, when the pH is in the 8 to 9 range, it is a good indication that some carbonation is taking place from the surface of the concrete toward the inside. The presence of carbonation allows more surface porosity and that coupled with the lower pH will allow more corrosion to occur in the rebar.
The most significant step you can take to protect rebar in concrete is to have a dense concrete with good cover over the rebar. Several studies have shown that high quality, dense concrete with a bit of extra cover does more to prevent corrosion than extra coatings or additives in the concrete.
In other words, if I drill a small hole in the walls, mix the particles from the hole with water and then measure low PH can I assume that there has been corrosion of any steel in the wall?
A well established test for loss of alkalinity is a phenopthalien indicator test - FRESHLY EXPOSED (ie freshly chipped or freshly fractured) concrete that is sprayed with a solution of 1% phenolphthalein indicator in 95% alchohol with turn bright pink if pH of concrete is > 10 and colorless if less than 8.
This will indicate the depth of carbonation, whereby the corrosion to embedded reinfrocing can begin.
Thymolphthalein indicator also works too - dark blue indicator.
1 gallon of 1% phenolphthalein indicator in 95% alchohol cost me less than US$50 (a few years back) and has last a few years. Place a small quantity in a spray bottle and you are good to go.
There's not much you can do to get around the need for a "chunk" of concrete. Something we often do is take a small diameter core (1-1/2" dia.) about 2 inches long, then turn it on its side like a splitting tensile test, load it to fracture and then you have a nice clean freshly fractured piece with a good gradient from the surface down.
The core hole can be easily repaired with mortar.
Did you mean phenopthalien or phenolphthalein?
-Kent
PHENOLPHTHALEIN is correct.
One manufacturer is RICCA CHEMICAL COMPANY, Arlington Texas.
Also, as Ron mentioned, small diameter cores are a good method to obtain a sample (that you fracture longitudinally, as he states). We use a HILTI hand-held core machine that works well for small diameter samples (1.5" for example), and avoids having to mount the rig with drop-in anchors or use a vacuum base.
HTH
My supply came from a conventional pharmacy... only need a little bit... and it is medically used as a laxitive...
Dik
I will have to remember that next time nature requires!!!
Dik
Can anyone simplify this for me a little by providing a recipe? What measure of phenolphthalein to what measure of what type of alcohol to make say... a pint of testing solution?
You can make it simple and go to JAMES INSTRUMENTS and you can purchase a small CARBO DETECT kit with a small quantity of PHENOLPHTHALEIN.
See the website at: http:
The PHENOLPHTHALEIN I use is 1% (w/v) in 95% (v/v) alcohol - not sure of if the alocohol is "isopropyl" or black label Johnnie Walker - I took chemistry classes along time ago.
dik,
I think I will use my PHENOLPHTHALEIN purely for concrete testing - my "system" keeps pretty regular with my balanced diet
Ingredients:
1 oz reagent grade phenolphthalien
10 oz isopropyl alcohol (70%)
6 oz Johnny Walker Black (JWB)
Procedure:
Inject 1 oz JWB onto tongue. Swallow quickly
Mix 1 oz phenolphthalien into 10 oz alcohol
Inject another 1 oz JWB onto tongue. Swallow quickly
Observe swirling in phenolphthalien/alcohol mixture. Watch for 30 seconds
Inject another 1 oz JWB onto tongue. Swallow quickly.
Observe concrete specimen, then mixture, then concrete specimen. Repeat
Observe swirling in mixture again. This time for 60 seconds.
Now try to find that concrete specimen again. Having difficulty? Inject the last oz of JWB onto tongue. I don't see any carbonation, do you?
