Solidworks CustomerPortal
Hello All,
I just looked up current SPR's at the SW website and noticed that SW has come out with a customer web portal. It looks pretty cool and is pretty easy to use until you click on "forgot password". Has anyone else tried it or have any thoughts on it?
Dan Olid
SW2006 SP4.1
PDMW 4.0
Cad Designer/PDMW Admin
RE: Solidworks CustomerPortal
You can get into the site with just a serial number, but you will have limited access. I found yesterday that the submit enhancement request link was broken, sometimes it would work, but others it would not. It would loop back to the page you started from. SW is aware of this issue.
It looks like they pulled the website for now to fix any broken things that have been found because now when you log in you get the old way of doing it.
This new login will be a pain like any change is, but it is going to be much more beneifical to you as a customer then you might think. You will a Knowledge base that is so much better then anything you have seen before and it stays updated to the recent version. That alone is worth having the new interface.
Best Regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Good to have a page of links upon entry such as the discussion board, hardware specs, etc.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I started a blog a couple of weeks ago and I posted my thoughts on the
SolidWorks subscription service this morning. I thought this might be
an appropriate time to do so since the new "customer portal" will be up
soon. I know this topic comes up here from time to time and I'd be
intrested in knowing if my thoughts are in the majority or minority.
If you have a chance, check out the post and add your comments.
You can access the blog from my website.
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 6/05/06)
SW 2006 SP 4.0
