coil spring material
Reverse engineering a coil spring for an aerospace application.
Mat'l report came back with the following % by weight;
Fe-49
Ni-44.83
Mo-3
Ti-2
Al-1
Cu-0.12
Mn-.10
C-0.02
Si-0.02
Any specific reason for the addition of Ti, Al?
I haven't found a material vendor that can identify the material.
Any help Mat'l I.D or with vendors that deal with special materials would be appreciated.
Fe-49
Ni-44.83
Mo-3
Ti-2
Al-1
Cu-0.12
Mn-.10
C-0.02
Si-0.02
RE: coil spring material
It is not simple to reverse engineer a spring even if you have the correct material. You can not just make a spring with identical dimensions. You have to know what metallurgical and mechanical processes the spring had. It may had a preset at room temperature or other temperature etc. You should calculate the stresses, fatigue cycle etc., and know the working conditions to successfully reverse engineer the spring.
http://israelkk.googlepages.com/home
This is for a US based supplier to a US based aircraft company.
I am leaning towards having a second analysis done at another lab to confirm the material composition as none of the spring material vendors I have contacted are familiar with the material.
Cory
Are you aware of a material that has a similar chemistry?
http://www.matweb.com/search/SearchComp.asp
Cory
Make sure that there is not a nickel coating on the wire that is compromising the analysis. Nickel coating is frequently used to act as a lubricant/reduce friction on stainless steel and other spring wires during the coiling process. What is the wire size? Do you know exactly how the analysis was performed, meaning how the sample was probed, what analytical method/equipment was used, etc.? This may be helpful for choosing a 2nd method.
CoryPad; The Matweb site is great.
Have a lab recheck the material for Cr.
Jack
Cr-0.02
Chemistry was verified by second lab.
