.025" Thk. S/S for small spring latch
Good Morning---
I'm in need of some advice about material selection for a small sheet metal latch I'm defining for fabrication. This is a smal latch with 3 bends, one bend past 90°. I need to define a S/S material that allows this item to be formed, w/o cracking and still remain as a spring type device once attached to it's mating part. Is there a material that lends itself to this short of buying basic 300 series SS, forming and tempering it to suit.
P.S.- I've had someone suggest material 301 1/4 hard SS but I'm afraid it won't form without cracking.Any help would be greatly appreciated.
RE: .025" Thk. S/S for small spring latch
You may use material such as 17-7PH condition C and after forming to heat treat (aged) to CH900.
http://israelkk.googlepages.com/home
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Did you do any stress calculations for the latch spring?
As for the calculations, I have none as yet but really appreciate your help on this.
You have two issues to balance, forming and service. You need softer material to form, but stonger material in service. You will not get there with a 3xx series, unless it turns out that using rather soft strip (1/8 or 1/4 hard) will be good enough in service.
Rust never sleeps
