Parasolid unit settings
I have just come across a problem I haven't seen before. If I export a parasolid from a file created in english units and then open that parasolid, it opens as a metric file. I've looked for a setting to change this, but have had no luck. Any ideas?
RE: Parasolid unit settings
To do what you are wishing to do, you should instead open a BLANK Inch units part and then "Import" the Parasolid model into it. NX will automatically handle getting the units correct for everyone concerned.
However, when you "Open" a Parasolid model directly, since we have no way of knowing from where it came, we had to pick a default set of units and since the vast majority of the world (including the majority of the NX user base) is using Metric units, we were safest assuming that the part was intended to be used in a Metric format.
John R. Baker, P.E.
Product "Evangelist"
NX Product Line
UGS Corp
Cypress, CA
Phone: 714-952-6032
FAX: 714-952-5758
John.R.Baker@ugs.com
