4" 150# lug BFV
4" 150# lug BFV
I have a 4" 150# Lug BFV on a chilled water return line that is leaking past the seat. I asked the owner and only the CHW with a rust inhibitor and am anti-bacterial agent are present. The original valve leaked and started to blow open even though the handle was locked in place. We put two other valves (1 brand spankin' new) on and both leaked past the seat, and by leak I mean about 1 gal/min.
The owner swears that the pressure in the main that it ties in to is only 70 psi, but this makes me think it is a lot higher than they think. But there are no pressure taps on the line.
Has anyone ever seen this?
RE: 4" 150# lug BFV
RE: 4" 150# lug BFV
RE: 4" 150# lug BFV
RE: 4" 150# lug BFV
RE: 4" 150# lug BFV
RE: 4" 150# lug BFV
I would try to get an idea of the true system pressure and if that appears normal, get the valve manufacture involved they may have some valuable imput.
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int./JCI
RE: 4" 150# lug BFV
