Need a heated, insulated fiberglass pump enclosure mfr
Something of a low-brow answer to Hot-Box. Simply can't afford them. Size is 4'x4'x4'. I realize I may have to use something other than fiberglass. Any ideas? thanks
RE: Need a heated, insulated fiberglass pump enclosure mfr
wpr,
BTW, I would think you may want to move this to the pump forum?
If you do, please "Red Flag" this thread after you move the posting.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
