Cross product of vectors - macro
Hi, I wan to build a macro which give me new vector using function MathVector.Cross . One of input vector is a normal of surface (for example plane) and a second is one of axis of origin. So, I want obtain vector emergent with this two inputs vectors... If this possible?If You have any ideas please describe... thanks
RE: Cross product of vectors - macro
I have simple program where I have a vector which represent normal of slected plane.Now I want to make a cross product between nthis vector and for example one vector of origin (x or y or z).How make taht?please help me...Below is a source code:
Option Explicit
Sub main()
Dim swApp        As SldWorks.SldWorks
Dim swModel      As SldWorks.ModelDoc2
Dim swSelMgr     As SldWorks.SelectionMgr
Dim swFace       As SldWorks.Face2
Dim swSurf       As SldWorks.Surface
Dim vPlane       As Variant
Dim swMathUtil   As SldWorks.MathUtility
Dim nVector(2)   As Double
Dim vVector      As Variant
Dim swFlatNorm   As SldWorks.MathVector
Dim ArrayData    As Variant
Set swApp = Application.SldWorks
Set swMathUtil = swApp.GetMathUtility
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swFace = swSelMgr.GetSelectedObject5(1)
Set swSurf = swFace.GetSurface
 If swSurf.IsPlane Then
 vPlane = swSurf.PlaneParams
 swApp.SendMsgToUser " Selected Surface - PLANE " _
 & vbCrLf & vbCrLf & " Normal  = (" & vPlane(0) & ", " & vPlane(1) & ", " & vPlane(2) & ")" _
 & vbCrLf & vbCrLf & " Root    = (" & vPlane(3) * 1000# & ", " & vPlane(4) * 1000# & ", " & vPlane(5) * 1000# & ") mm" _
 & vbCrLf & vbCrLf & " File    = " & swModel.GetPathName
 End If
nVector(0) = vPlane(0):     nVector(1) = vPlane(1):     nVector(2) = vPlane(2):
vVector = nVector
Set swFlatNorm = swMathUtil.CreateVector((vVector))
ArrayData = swFlatNorm.ArrayData
 & vbCrLf & vbCrLf & " Vector of normal = (" & ArrayData(0) & ", " & ArrayData(1) & ", " & ArrayData(2) & ")"
 GoTo CleanUp
CleanUp:
Set swApp = Nothing
Set swMathUtil = Nothing
Set swModel = Nothing
Set swSelMgr = Nothing
Set swFace = Nothing
End Sub
You've got 99% of what you need here.  All that remains is for you to do the cross product.  Declare a variable as
Dim swCPVector As As SldWorks.MathVector
Then, once you've created swFlatNorm with swMathUtil.CreateVector you can cross it with a (1,1,1) vector like so:
set swCPVector = swFlatNorm.Cross(swMathUtil.CreateVector(Array(1,1,1)))
Sorry, brain fart.  What you want is more like:
CODE
Dim swCPwithX as SldWorks.MathVector
Dim swCPwithY as SldWorks.MathVector
Dim swCPwithZ as SldWorks.MathVector
set swCPwithX = swFlatNorm.Cross(swMathUtil.CreateVector(Array(1,0,0)))
set swCPwithY = swFlatNorm.Cross(swMathUtil.CreateVector(Array(0,1,0)))
set swCPwithZ = swFlatNorm.Cross(swMathUtil.CreateVector(Array(0,0,1)))
Oh, Thanks handleman.I amke something like You... but your proposition is good. I think about this, that one of component to  cross product (You proposs swCPwithX or swCPwithY or swCPwithZ) will be perpendicular to normal of selected surafce... I try use function in MathVector but there are nothing... (I think so..) How make taht?For example: if normal of surface is (1,0,0) that vector which I use to cross product is (0,1,0) or (0,0,1).If You know how make it, please help... Thanks
I'm don't understand what you are asking.  The result "swCPwithX" will be perpendicular to the plane normal and to the X axis of the part coordinate system.  Similar for swCPwithY and swCPwithZ.  I'm not sure what end result you seek.
Yes, You have right handleman.But this is only good when normal is (0,0,1) or (0,1,0) or (1,0,0).And how willbe perpendicular vector when normal willbe for example (0.4251, 0, 0.687)?
I'm afraid I still don't understand what you are trying to do.  Why are you interested in finding the cross product?
So, I want obtain a coordinates system where one of axis is normal to surface(vector of normal). Next axis must be a orthogonal to this normal. When I have this two vectors I can obtain third vector using cross product...
One vector is not enough to define a coordinate system.  If your normal vector is the X-axis of your new coordinate system then the Y and Z axes can still be any direction along the surface.  You will have to do two cross products.  The first one will be with one of the part's axes and the other will be a cross of the result and the original normal vector.  Something like:
CODE
dim MyNewXaxis as SldWorks.MathVector
dim MyNewYaxis as SldWorks.MathVector
dim MyNewZaxis as SldWorks.MathVector
Set MyNewXaxis = swFlatNorm
set MyNewYaxis = MyNewXaxis.Cross(swMathUtil.CreateVector(Array(1,0,0)))
'[check here to make sure that the value of
'MyNewYaxis is not (0,0,0).  If so, cross MyNewXaxis
'with (0,1,0) to get value for MyNewYaxis
Set MyNewZaxis = MyNewXaxis.cross(MyNewYaxis)
Ok handleman, Your proposition is good.Thanks for Your time and patience:)!
