CORROSION TABLE RELATED TO CHEMICAL SUBSTANCIES
Hi Fellows!
I have a pharmacy lab, which I have to treat in terms of ventilation/hvac.
The substancies which are manipulated in process are
Glicerine´
eters
acetone
benzoico acid
boric acid
borat sodio
tartaric acid
sodio bicarbonat
eosine
etanol
dietilic eter
sidio hipoclorit
iodine potassic
mercurochrome
hydrogene peroxid
liquid vaseline
Maybe, there's only a few left.
I'm looking for the corrosion table having those kind/family of substancies to realise the requirements I have to fullfil in order to select the correct materials, concerning the HVAC installation, air ducts and airs units, "UTANS" as well air extracting ventilators.
Thank you in advance for any tip.
Cheers,
Welch
Glicerine´
eters
acetone
benzoico acid
boric acid
borat sodio
tartaric acid
sodio bicarbonat
eosine
etanol
dietilic eter
sidio hipoclorit
iodine potassic
mercurochrome
hydrogene peroxid
liquid vaseline
Cheers,
Welch
RE: CORROSION TABLE RELATED TO CHEMICAL SUBSTANCIES
http://www.compasspublications.com/guides.htm
Good general information about many materials and chemicals.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
