Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I frequent other newsgroups, too, and am MOST IMPRESSED with the lack of smart a-- and presence of genuine desire to help anyone of any skill level..."
Geography
TangoCleveland (Mechanical)
12 Jun 06 10:01
We're having a discussion about requirements for lift levers on RVs.  ASME BPVC Sec VIII Div 1 para UG-136(a)(3) states "Each pressure relief valve on air, water over 140°F (60”C), or steam service shall have a substantial lifting device . . .".  We interpret the "air" fluid as being ambient air with potential high humidity, and condensate in an air receiver tank.  Our service is research air, filtered and dried to a -90F dewpoint.  We  have never lifted lift levers in our system; we remove RVs and bench test periodically either in-house, or at a VR shop for Code valves.  Lift levers make valves expensive.  I noted in an API RP520 task force meeting (4/20/2005) that "Nobody in room understands the technical justification for the lifting levers. "  Since we are testing valves on the unit or on the bench (per NBIC 23, RB3550), should we require lifting levers?
Larry
Ashereng (Petroleum)
12 Jun 06 11:12
I guess the simple answer is, if you need to meet ASME requirement, you need a lift lever for air service (and hot water and steam).
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Helpful Member!  EGT01 (Chemical)
12 Jun 06 23:18
TangoCleveland,
You may want to review ASME Code Case 2203, there are instances when lifting levers can be omitted for Section VIII but not for Section I equipment.  Here's a couple of links that will give you some insight...
http://www.prdtechnologies.com/id19.htm
http://www.nationalboard.org/NationalBoard/Nbic/Interpretation/1998/Interpretation_1998.aspx
13 Jun 06 8:48
EGT01,
Thanks.  That's exactly what I'm looking for.  Much appreciation!
Larry
Close Box
Join Eng-Tips® Today!
Join Us             Close
