Directivity calculation in Matlab for circular array-suggestions?
Hi everyone,
Could someone help me out in calculating the Directivity of my circular array. I'm using Matlab and I'm pretty certain my method is not correct (explained a little below).
Very Briefly, this is how I generate the Array factor:
         a1=-50;b1=50;c1=.2;
         [fx,fy]=meshgrid(a1:c1:b1,a1:c1:b1);
         t=linspace(0,2*pi,250)
And inside a loop:
      for k=1:length(t)
      x=cos((t)+offset); y=sin((t)+offset);
ArrF=exp(-i*2*pi*(fx*(rad(j)*x(k))+fy*(rad(j)*y(k))));
 plot(rad(j)*x(k),rad(j)*y(k),'.b');
 AF1=AF1+ArrF;
And I plot it with:
dbaf=20*log10(abs(AF1));
mesh(fx,fy,dbaf);
And this is how the Array and the Array factor looks if that helps:
http://img110.imageshack.us/img110/5355/af7rq.jpg
So now I have my Array factor AF1 which is a 501x501 array and here is where I could use some help in calculating the directivity.
I tried calculating the directivity this way:
theta=linspace(0,180*pi/180,501);
phi=linspace(0,360*pi/180,501);
[thtmesh,phimesh]=meshgrid(theta,phi);
dth=theta(2)-theta(1);
dph=phi(2)-phi(1);
Prad=sum(sum(abs(AF1).^2.*sin(thtmesh)*dth*dph));
Directivity=4*pi*max(max(abs(AF1).^2))/Prad;
But as I mentioned...I doubt this gives a correct value...I used linspace to set theta and phi to 501 so that the matrix dimensions match AF1...and I have no clue if the value I get is right.
Could someone help me out with the Directivity here?
Sorry if my query is too long but I thought it would help if I was as descriptive as possible.
Thanks!
RE: Directivity calculation in Matlab for circular array-suggestions?
Average directivity should be 0 dBi (assuming that the mass is constant *).
* subtle joke.
Directivity for most antennas is pretty accurate (in dB) as 10* log [41,000/[(beamwidth 1)*(beamwidth 2)]]. beamwidth 1&2 are principal planes in orthogonal (perpindicular) directions.
compare that to your results as a quick check, it should be within 1 dB unless those sidelobes in your chart are very high.
kch
