Resistive Cards Modeling in CST
I am trying to analyze in CST a waveguide assembly which includes a resistive card made of a material which has a resistivity of 150 ohm/square.
The card ascts as a mode supressor.
How do I define the material properties?
Any suggestion would be appreciated.
tuli
RE: Resistive Cards Modeling in CST
I don't use CST, but I do use ANSOFT HFSS.  Couldn't you just assign an impedance to the surface of the resistive card? In HFSS, you just pick the surface and assign the impedance in ohms/square.
David
