how to calculate wattage for tank heaters
I need to  keep a 1000 gallon outdoor concrete tank from freezing down to 0 degrees F. I see most immersion heaters provide a KW rating but I don't know how to determin the power I need. thanks
RE: how to calculate wattage for tank heaters
Calculate the heat loss.  Heat input needs to equal the heat loss at design conditions.
Presumably, you can calculate the heat loss from the tank in terms of btu/hr or calories/hr then apply the conversion factors to determin Watts or Kilowatt which should be the rating of the electric heater.  Dont forget to apply a fudge factor to your final value.
