Need Some Help On Converting Pro/e Files
Was wondering if i could get some help on converting
Pro/e or Pro/engineer Files
To one or all of the following
Flash
Swift 3d
Lightwave
3d Studio MAX
Any Help Would Be Great
RE: Need Some Help On Converting Pro/e Files
As far as a file converter, I don't know of a standalone or web-based solution for the platforms you mention.  I have been closely tied to this issue for over a year now, and found that file converters only exist for the higher-end CAD packages (ProE, CATIA, UG, I-DEAS).  For others, the only feasible solution is neutral files (IGES or STEP), but unfortunately you are left with a 'dumb solid' which cannot be modified.
Recneps
If you can use a flash file, can you use the VRML format?  It is veiwable through the Internet explorer and the user can spin pan zoom.  The VRML publisher is built right into Pro Engineer.
