ôVariable Primary Flow Chilled Water Systems
I thought some of you might be interested in this:
The Air-Conditioning and Refrigeration Technology Institute (ARTI) has released a final report on a research project titled “Variable Primary Flow Chilled Water Systems: Potential Benefits and Application Issues.” To download a copy of the final report, visit the ARTI Web site at www.arti-21cr.org.
RE: ôVariable Primary Flow Chilled Water Systems
Another word of advice, be sure that the condenser water temperature is allowed to drop as the flow/load decreases.
We had to replace the thrust bearing on a machine less that two years old. I feel a lot of the surging was caused by the control system resetting the chilled water flow from outside air temperature, with no reguard to the rate of change (possibly too sensitve to ambient change would be more accurate), that and a cooling tower system set to provide 80 degree condenser water come hell or high water.
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int.
See the following links for the report (volumes 1 and 2)
http://
http://
