BOM _ component name
I thought if in my assembly I picked a component and went to component properties then changed the component name that it would update my BOM to reflect that name, but it does not. I can open and rename each component individually but I'm wondering if there's a different way so I don't need to do this.
RE: BOM _ component name
What is your BOM actually reading?
What property are you changing?
The standard BOM reads the filename (the name the component is saved as) & the description from the properties.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
