GetAngleBetween Object doesn't support this property or method
We are creating a macro to get the angle between 2 lines.
We are using the GetAngleBetween Method, but we get the following error:
Object doesn't support this property or method (Error 438)
We are using the example from the CATIA help below.
Please let us know if you have run into this and know of a fix.
Joseph
This example retrieves the angle between the reference1 and reference2.
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromObject(object1) Dim reference2 As Reference
Set reference2 = part1.CreateReferenceFromObject(object1) Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench ( "SPAWorkbench" )
Dim TheMeasurable As Measurable
Set TheMeasurable = TheSPAWorkbench.Measurable(reference1) Dim MinimumDistance As double
MinimumDistance = TheMeasurable.GetAngleBetween(reference2)
RE: GetAngleBetween Object doesn't support this property or method
Figured out the problem, the documentation is not correct the following line:
Should read "GetMeasurable" not "Measurable"
Thank you,
Joseph
