a cancel/close commands to stop the running of the messagebox?
How can I put a cancel/close commands to stop the running of the messagebox? (the records are thousands of records long).
CODE
    While rs.EOF <> True
        MsgBox (rs("book_title") & " " & rs("chapter") & ":" & rs("verse") & " " & rs("text_data"))
        rs.MoveNext
    Wend
Or do you have a better suggestion? Instead of coding msgBox what way can I put a table of records?
RE: a cancel/close commands to stop the running of the messagebox?
Use a data grid
