1MVA Generator
1MVA Generator
What is typically used as a main feed off a generator unit?
Basically, there is a 1MVA generator followed by a 600-4160V step up transformer. I have to install a disconnecting means to feed a mine distribution system.
What typically is used for this? It has been suggested to use a S&C 5kV fused disconnect along with a Toshiba 5kV Vaccuum contactor. Also it has been requested that a multilin relay be used for GF.
Are there any conceerns I should watch out for when dealing with generators?
TULUM
TULUM
RE: 1MVA Generator
