Sealing a furnace
Sealing a furnace
I am in the design of an Argon atmosphere furnace and i need to know how can i do to seal the internal walls of the furnace to avoid the gas leak. Is it enough with the refractory cement? or should i try with another material?.
The max temp the furnace will reach is 1100 degrees celsius.
RE: Sealing a furnace
Information like:
Is this an existing furnace?
Do you plan to use a muffle?
What is the size?
What is the end use?
What type insulation?
Anything else you can think of.
My idea is an electrically heated furnace with the heating elements exposed to the inner atmosphere. The size is: 1.8m height, 2m wide, 2.5m deep, for a 9 cubic meter inner space.
The end use is to give a stress relief to titanium pieces after a welding process and to heat treat steel pieces of many shapes and sizes.
I want to use an insulation blanket of high purity alumina, silica and zirconia.
I will apreciate any help you could give me. By the way, if you know some website to get info about furnaces let me know.
http://www
I think your best bet would be to look on the surplus market for furnace and even then you are talking about large sums of money for a furnace of you dimensions.
This is one company that makes suitable furnaces for heat treating Ti.
Comeback if you have further questions.
http://www.elnik.com/heat.html
David Pye, Pye Metallurgical
E-mail Address(es):
davidpye@pyemet.com
He had sent me details of a few used vacuum furnaces sometime ago. Hope they are still available.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
