Exporting pipes to .igs, .stp or .3DXML
Hello all,
I'm using Catia v5r16 and doing a thermal plant layout with pipes made in piping design module. When I try to export the model in .igs, .stp or .3dxml, the model translates correctly except all the pipes are gone. Fiddling with .stp options got me to get the pipes in the Tree, but nothing on the screen (no, they're not hidden), and also nothing in softwares where I try to import. Please help?
RE: Exporting pipes to .igs, .stp or .3DXML
I don't think you will have some luck...You can try this http://2htts.com/CATBlog/index.php?itemid=19#more (if you con't have so much to replace...)
Fernando
