Engine Exhaust Plumes
Is it true that the engine exhaust plumes diverge from 1 another on the port side and converge on the starboard side in the case of a 4 engined aircraft,?
Does anyone have an explanation for this? Is this phenomenon dependant on factors such as temperature, pressure, etc.?
Thanks.
Thanks.
RE: Engine Exhaust Plumes
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Albert Einstein
