unbalance voltage
unbalance voltage
hi
when generator run, measured voltages : Vab= 417, Vbc=420, Vca= 392.
Vca is much lower than the others. what's the problem ? how can i fix it? thanks
RE: unbalance voltage
What are your loads comprised of?
Single phase and 3 phase?
What kind are they?
Keith Cress
yours
Is it possible to measure the winding resistance between terminals?
What size is the generator?
Is it delta or wye?
If it is wye, is the center point grounded?
Have you tried putting a load on it?
yours
it's ok when i put load on it. but the voltage is still unbalance. the generator is paralled with other generators.
may be the ground resistance is high ?
