ultrasonic transmitter cable
Hi folks,
I want to send 150v 0.4amp to a remote ultrasonic transducer that has 200 ohm impedance. The NPN driving ciruitry will be about 3-4' from the transducer housing. Digital circuitry will be nearby. What specific brand name/type cable would one recommend - it may bump or rub up against the operator. I was thinking about using in-wall audio speaker cable.
RE: ultrasonic transmitter cable
"...150v 0.4amp ... 200 ohm impedance..."
150/200 is 0.75A.
Cable probably not critical, but the operator should not be anywhere near 100 watts of audio, even if ultrasonic.
50 ohm coax will probably do because the cable length is very short compared to the wavelength.
Current source to transducer is only 0.4a. Transducer can't draw more than what's available. Sounds like I am making an ultrasonic weapon more than a transmitter by your concern. I will ponder your concerns. Thanks for both replies.
GoKid!
Yeah I'm wondering too.. What about the TIG welder next to me that is packing 8.2kW of square-wave.
Keith Cress
"TIG welder"
To make sure it's clear: I'm more worried about the operators ears (100 watts of audio, even if ultrasonic) than his elbows (high voltage/power in a cable).
Ah ears... That makes sense.  We thought you were referring to the electrical energy.
Keith Cress
A few things to consider.
1. Transducer driving signals can be either a continuous signal or a pulsed signal.  You may need to consider the effect the cable has the shape of the signal, particularly with sharp pulse envelopes.
2. Ultrasonic transducers are generally a capacitive load so the capacitance of the cable is important as it acts like a voltage divider.
Its a single 40KHz wave repeated every 10ms.
The power transducer is usually driven with its resonance
frequency - in this case you can't generate a single
wave for it will not reach a significant amplitude and
it will ring for time depending on the Q.
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
