splits and solar energy!!!!!!!!!!
I'm a automotive engeneer but I have to do an assignment witch comprises:
·    Improving and completing test arrangement
·    Making a simulation model to match
·    Drawing up measuring protocols and performing measurements
The test arrangement comprises the following parts:
·    Heat pump
·    Solar collectors
·    PV panels
·    Buffer reservoirs
·    Vertical ground heat exchangers
·    A low-temperature emission system
The aim of the test arrangement is:
To find the cheapest possible space heating system with a net power input exclusively from solar- and ground heat.
This translates into a search for:
·    The most appropriate configuration of the test arrangement
·    Optimum correlations between:
v    Dimensions of collectors and panels
v    Heat exchanger power
v    Heat pump power
v    Size of buffer reservoirs
If some one can help me about this subject please do it!!!
advenced sincerly thanks,
holand
RE: splits and solar energy!!!!!!!!!!
Dear Holand,
quite a few universities have done research on this in the Uk, France, germany and the US.
you can find those research papers through a university library or local library; Some universities offer there service through the web.
Heat pumps connected to solar power is commercially avaiable. Try at little searching on the web.
A quick search or google led me to theese guys:
http://www.ghpc.org/home.htm
Best Regards
Morten
